ESolar
- Eureka, CA Humboldt County
- Electrician/Contractor
Am I correct?: One concern with adding solar is that the backfed solar source can allow the loads on the bus bar to be greater than the OCPD without tripping because they are offset by the solar. As a result, the busbar rating may be exceeded by the loads causing expensive and dangerous catastrophic failure. The derating of the main OCPD, if necessary, specifies that the solar feed is limited to (120% of Bus Bar Rating A) - (Main OCPD A). The derating is to protect under conditions when the load may be more than 120% of the busbar rating and not trip the OCPD (because solar reduced what the OCPD sees). The derating is not designed to limit the load beyong that limited by the panel and feeder. The code says nothing about reevaluating and reducing your load (which might exceed derated OCPD) when adding solar - it instead specifies limits on the OCPD to protect against a load significantly exceeding the busbar rating without tripping.
