I have a 20HP motor that will be used in a 575V, 3 phase system. The FLA per 430.250 (2017 edition) is 22 amps, which yields 27.5A when applying the 25% factor required.
This will be operated at a 40 deg. C ambient environment. I am sizing the wire for this motor. I have been burned (figuratively) by wire sizing in the past (see post history, ripping out conduit is not fun), so I am trying to make sure this is done right.
From what I have learned, motors have 75 deg terminals (NEMA design). This being the case, do I start with the 75 degree column of 310.15(B)(16) and derate from there? If so, then I get #8 AWG, but this doesn't make sense to me since I am using THHN (I mean, that must have some relevance right?)
Do I look at the 75 deg column, and compare the values to 27.5A?
If I do the this, I see that 27.5A would correspond to a #10 AWG conductor. I then take #10 THHN, which has an ampacity of 40A, and then adjust it for 40 deg C using the formula in 310.15(B)(2) --> (0.912871 * 40) = 36.52, which is greater than 27.5A, so this would be acceptable.
Is this the correct process for sizing wires when terminal ratings do not match the wire rating?
