Other than being covered in Annex B when applying the derating factors for conduit fill is it permissible to use actual load (Table FLA) values :?
For example, you have (5) motors each with 10 FLA on 25 amp breakers. NEC allows #14 conductors. If all 5 are fed thru one conduit, 15 conductors #14 derates to
12.5 amps. O.K. by Code to use the FLA of 10 amps X 1.25 ??
