I am wanting to feed two well pumps from a 480V 3-phase service using one feeder.
The pumps are both 5 HP and will be run continuously. The first pump will be located 1350 feet from the service and the second pump will be an additional 300 feet away.
My design is to run a #3 conductors protected on a 30 amp breaker from the service to a j-box at the first pump then to a fusible disconnect (20 amp fuse) and from the j-box to the second pump feeding directly into a second disconnect.
Is this the most cost effective design?
