I still can't get this detached building (garage/shed) together in my head.
I'm planning on running a feeder to the building for a panel and will give the owner the option of mc or nm in the residence to feed the exterior incase he thinks about putting in a pool someday.
If he wants a light on the detached building with a 3 way between the house, I still don't know how to handle that.
From what I understand, I don't think the feeder can supply a circuit coming back to the building it originates from.
And as far as a light on the detached building (or two lights... one on detached building and one on the house) operated from 2 3-way switches and the circuit coming from the house.
Is that permissible? The switch in the shed would act as a disconnect but it's a 3-way?? Would I also have to add a single pole inside or outside??
I'll open the book again, but I'm not getting it?
any advise much welcome.
(as I side note (question). for the panel, is it treated like the main ground rods.. just install two and be done with it? Or is 1 expectable?)
Thank you
Thank you
