Replacing overhead feeder to a two car detached garage. The Sub panel is a 60A inside the garage. The Main service panel at the house is exterior mounted facing the garage 25' away.
My question is: am I required to install a disconnect on the outside of the garage where the sub panel feeder wires will enter the garage or since the main panel is within sight Is that considered my disconnect to the garage?
If a disconnect is required on the garage can it be a pull out A/C type or must it be a switch type?
