Detached Garage existing wiring, will it meet code?
jbradley2093
Mid-Michigan
Real Estate Investor
I am rehabbing a 75 year old house. At some point more recently (than 75 years) a detached garage was built and a single 12/2 UF wire was directly buried in the ground and running from the panel inside the house directly a disconnect in the garage and then to the outlets and light in the garage, there is no sub-panel. This is the only part of the entire electrical system I had intended to leave alone. My only intended modification was to install a 20a GFCI breaker at the panel. Does this configuration meet existing code?
Also, the UF wire comes out of the ground at the garage (its buried about 2 feet deep it appears) and is unprotected as extends from the ground and up about 8 inches up the wall before going into the garage. I assume I need to protect this portion in conduit on the outside of the garage?
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
