618electrician
- St. Louis
- Maintenance electrician
In a detached garage / you need ground rod / gfci / disconnect / mwbc/ or sub feed / ?????????????????????????????????????????????????????????????????????????????
MWBCAre you feeding it with a branch circuit or a feeder?
Disconnect required. No GES connection required.MWBC
MWBC
A 2-pole switch can be the disconnect.Disconnect required. No GES connection required.
