I want to run power to a detached metal pole barn/garage from my friend's home panel. He has a 200 amp service to the house and wants 100 amp service to the garage. I know how to size the wire and do the work, but I don't know how to determine if the 200 amp panel in the house is sufficient to power a 100 amp sub in the garage. He also already has a 70 amp sub in the house. The local inspector said he won't require a load calc. since all he is gonna run in the garage are lights, gen. use receptacles and a small air compressor....but I don't want to overload the panel in the house. If I do a load calc. how do I figure it for the garage? Is there anything that says I can't put a 100 amp breaker in the house panel to feed the garage even if I am only going to use 50 amps? (besides obvious extra cost) ( He wants room for future expansion and has already had another electrician run the wire and install the panel in the garage.) If the house calcs. at say 150 amps, can we still use the 100 amp breaker to power the garage sub panel?
Any and all help is greatly appreciated!!
