The reason for my question is to determine if 6-2 NM-B or NM-C/UF-B should be used when installing a 7.5 HP compressor in the indoor area between two overhead doors. The cable will be run inside the wall cavity from the main panel to a QO200TRNM AC disconnect switch rated for 60 A/10 HP. I've called three supply houses in my area and none of them carry 6-2 UF-B cable, only 6-3, although they can order some for me.
