Ravenvalor
- Piedmont region of NC
Can someone please give me the code reference for calculating the feeder load for a residential detached garage?
Thanks
Thanks
Either 220.12 which may not help but 220.14 may.Can someone please give me the code reference for calculating the feeder load for a residential detached garage?
Thanks
Thanks for the tip. That is where I have been looking though. It appears that I have to calculate 180VA for each receptacle in the garage?
What are you wiring in the garage? A few outlets? Are you adding a panel?
I am installing 15 - convenience receptacles, 2 - garage door opener receptacles, & 3 - 8' 2lamp strip lights for the unfinished portion. I am installing 1 - overhead light and 4 - convenience receptacles for the finished portion, & 1 - 2lamp flood light on the outside. I will install 1 - electrical panel in the finished portion.
Suemarkp is leaving me to believe, especially after reading 210.52(g) I probably should calculate the load at 3VA per sqft.
Thanks,
