SeniorInspector
Can someone explain to me where all the 6 disconnect rules may apply.
Example : If we have a detached structure and it has a 60A panel in it ( lets say a garage ). Can they get away with the 6 disconnect rule or is a disconnect means required at the garage.
In other words, can they have a 6 space panel with single pole breakers in it and no disconnect on the feeders to the seperate structure and still comply with 225.31
Would 225.33 would allow 6 single pole breakers in a sub-panel to the garage above with a disconnection means on the feeders to the sub-panel.
408.36 is met at the panel inside the dwelling and is on a 2 pole breaker so that is met so we are not dealing with overcurrent protection at the detached structure. I am trying to figure out if the 6 throw applies here and no disconnect means needed on the feeders at the new structure.
