As per 220,87 I have contacted the POCO and found out the max demand on a 3 phase service is 53 KW.
Using the formula Watts = Voltage X current x 1.73 I come up with 127.64 amps
Am I correct?
Do I need to use POCO power factor when I do this formula.
I have a 320 amp continus meter pedestal so I can load that to
240V times 320A times 1.73 which would be 132 KW
Again am I doing this correctly.
I find many formulas that mention using the power factor but am having a hard time obtaining this from the POCO
This is High Leg 3 phase system so my voltage 240V phase to phase.
Thank you
Am I correct?
Thank you
