Determining battery charger current draw
Designer69
I have a Ingersol Rand HP1600WCU compressor with a Cummins QSX15 engine that has a battery charger. A 120vac circuit supplies power to the battery charger.
We are extending these cables and I have to run voltage drop to make sure it's ok.
I can't find the battery charger current draw anywhere. Looked thru the Cummins QSX15 specs and the Ingersol Rand HP1600WCU compressor.
any help?
mgookin
Fort Myers, FL
Any Questions?: Ingersoll Rand Air Compressor Engineers Ready to Help. 631-342-1171
That's the best I can find. They require a login to access manuals.
topgone
any help?
Please see if I read your problem correctly. You have an engine-driven compressor and you want to transfer its battery away from the engine skid, hence you need to size the cables, right?
It's really simple. Know your battery rating--> AH a.k.a. "ampere-hours".
The standard discharge/charge rate is 8 hours;
A = ampere-hours/8 hours = amperes draw at 8-hr rate! That would be the amperes running from your charger output terminals to the battery, thru the battery cables.​
OTOH, if it is the charger that you will be transferring together with the battery, you'll need to convert the DC output amps into AC values by calculating the DC power at 8-hour charging rate.
DC power = amps DC x Volts DC = xxxx watts
AC power = DC watts/ efficiency of charger;take eff= 0.90
AC amps = AC power/120V​
Sample problem: car battery Power Patrol SLA1185, 12V, 100AH
Charging amps = 100A-hours/8 hours = 12.5 amperes DC
AC 120V charger amps = [(12.5 x 12)/.90] / 120 VAC = 1.39 amperes AC
Hope that helps!
