With a normal generator you have a static magnetic field, and the action of the copper moving within the static magnetic field causes voltage to be generated. The AC waveform generated is in strict relationship to the pole configuration of the genny, so typically a generator will output two complete waveforms per phase, so a genny rotated at 1800RMP outputs 60Hz juice.
With a DFIG genny the exciting field is not fixed and static, but is rotated electrically. Thus there is a third element to the relationship the output voltage has to the rotational position. Imagine it as having the effect of the generator rotating. if the field rotates in the same direction as the rotor, then you get less output cycles per revolution.. Rotate it the other way you get more.
Traditionally, generators that are connected to a line must be syncroniosed to that line, the generator not only has to rotate at the same frequency, but in phase. With a DFIG the relationship is broken, the generator can rotate at any speed, and the electronics driving the field makes the generator output power at the right frequency and in phase.
A Siemens innovation, I believe.
IGBT (Insulated Gate Bipolar transistor) are a relatively new type of semiconductor device, which posesses some of the best fatures of bipolar devices and MOSFETs, and are now seen in many applications, train traction control, inverters, DFIG field drive and dimmers to name but four. One very cool feature is that in a properly designed circuit you dont need to fuse the things; the controlling electronics detects the over-current and simply turns the IGBT off for a couple of cycles, then tries again. Having stage lighting dimmers that dont pop fuses when the lamp goes short is a very nice feature, and once the patents expire, one we'll all benefit from.
