exp
- SF Bay Area
- Electrical Engineer
Hoping to find some people with historic knowledge here.
Today I found what I think is the original main service panel hidden in a wall cavity of my 1929 house in the Bay Area.
People have pointed out this was a larger appliance disconnect and can’t be service because it’s just 120V.
However, the box was found in an abandoned external wall cavity right next to the service entrance. It’s clear that it was a wooden enclosure with an exterior door and that door has been removed, replaced with plywood and out stucco over.
In this cabinet it not much room for more than this one panel. On the panel side is a thick iron conduit which goes outside. It is exactly where the service enters now. From the top, abandoned K&T exists that has been capped a bit farther downstream.
The location of the cabinet is the corner of the living room where definitely no appliances were.
All of this makes me very strongly believe that this was the original fused main service disconnect and from there, a K&T run went to another sub panel.
Were there 120V/30A services in the Bay Area which would make this a plausible explanation?
PS: in the pictures I enter the cabinet from the back. I found it while installing new ductwork and removing the piece of wood which used to be the backside of the cabinet.
