F fnluk Member Jun 12, 2006 #1 Please try and settle a disagreement.Can die cast set screw emt fittings be used on the drywall [ie exposed] in a attached garage or is it a ul listing or requirement to use steel fittings? Thank you
B bphgravity Senior Member Location Florida Jun 12, 2006 #2 I believe this is a design consideration and not a listing or NEC issue.
roger Moderator Staff member Location Fl Occupation Retired Electrician Jun 12, 2006 #3 I agree with Bryan, it's a design issue. Roger
