craigwithak
I have done some research but am still confused as to how to meet the code requirement, 550.17, 2005 NEC applies to the work I am doing. I don't understand which test , Hipot, Megger, or other will fit the application. I am installing a 100 amp panel 208/240 power and 3 to 4, 15 to 20 amp branch circuits (lights and receptacles). Also a 1 ton HVAC unit with a 2 pole 30 amp breaker. I am using M/C cable 12-2 w/ground, and #8 stranded wire on the HVAC. I am hoping to not have to spend 1000's of dollars on test equipment. Any input would be appreciated. Thanks
