Low tension and high tension I think.I believe LT and HT are over the pond terms for low voltage and hi voltage.
In Europe, usually in Latin language [as French, Spanish, Italien, Romanian] speaking countries the word used for "voltage" is "tension?. However, even in IEC 60038 Standard Voltages the used word is "voltage" not ?tension?. I don't see why in India-I read in some posts-the term "tension" is still used.:roll:
Tension was used prior to the 1970's in US, but voltage was also. High tension lines for high voltage lines for instance.
