I am trying to get a clear definitions of Tap box,Pull box and Junction box.These are the definitions i came up with.
Pull box:Where you can pull cables in or out.
Tap box:As the name itself implies you are making the taps inside a tap box.
Junction box:Where you splice the cables like the ones we have in residential wiring.
Am i correct on these definitions or is there something i am missing?
And also i want to get a better definition between a splice and Tap.
Splice:Joining of two conductors....Question i have here is can you join tow conductors of two different sizes.If so are there any limitations or rules that you need to follow.I know that when you splice two wires of same sizes you can run as long as you want to but what about when you splice two conductors of different sizes?
Tap:Although we have a definition of tap conductors in NEC i want to get a better explanation on tap conductors...
I would appreciate if anyone can add on to my definitions or any modifications.I would like to get the basics right..
