Mark Twenhafel
Is there a difference between the D and D3 dies? I used an Burndy H-crimp yesterday with a Kerney crimper. The Burndey crimp specified D3 die, and using the Kerney crimper with the die labeled D left it loose.
So I went ahead and used the O die to make the crimp tight, not closing the handles all the way. I know this sounds shady and sketchy, but it's not for current. This was the bond from a transformer to building steel, which was actually a 3/0 in the riser of this concrete building.
I'll take criticism and flaming in good faith, but I really want to know if there is a size difference between the D and D3. Thanks.
