Using theory, explain what sum of the difference of/in potential of all the charges in an electrostatic field is refferred to as emf (voltage). Can you explain what are the electrons doing that causes a difference of/in potential. Please simplify
Can you edit your post to clarify and clean up mis-spellings?
If you are referring to electrostatics, then this is charge and potential requires a difference in charges. Two plates with the same number of free electrons will have no potential between them. Two plates, each with a different number of free electrons will exhibit a potential difference. EMF is electro-motive force, which is the measurement of current flowing between two locations across an impedance. As soon as you attempt to meaasure EMF, you discharge the charge difference. Unless there is a source of free electrons to restore the charge difference, EMF will become zero, like discharging a static electric charge.
.More formally, emf is the external work expended per unit of charge to produce an electric potential difference across two open-circuited terminals.[2][3] The electric potential difference is created by separating positive and negative charges, thereby generating an electric field.[4][5] The created electrical potential difference drives current flow if a circuit is attached to the source of emf.
Also you mis-spelled measure
Using theory, explain what sum of the difference of/in potential of all the charges in an electroctatic field is refferred to as emf (voltage). Can you explain what are the electrons doing that causes a difference of/in potential. Please simplify
