jph320
- Cinnaminson nj
- Electrician
What is the difference
If you were to attempt to drive an all copper rod in even moderately hard soil you will smash it to some degree. Steel core is necessary for strength, copper cladding is necessary for corrosion resistance and improved conductivity to the soil.The material they are made of and all of the "copper" ground rods I have seen are copper clad.
Or i can just drive a 3/4" RMC and use that.
A study by Erico a few years back of exhumed rods showed that there was a large difference in the longevity of the two types. As I recall they claimed that galv rods had a good amount of deterioration after nine or ten years, but copper-clad would take about forty to get to the same point.
I would think that could vary on the type of soil and minerals in the soil. maybe?
Lastly I am always suspect of studies completed by manufactures.
Sure you can.Or i can just drive a 3/4" RMC and use that.
Sure you can.
And if you have too, you can go and meet the inspector with your codebook and your file of twenty-seven, colour, glossy, photographs, with circles and arrows and a paragraph on the back of each one, to be used as evidence for the reason he is wrong for rejecting you.
Sure you can.
Is it legal or not?
You should know by the seeing eye dog he has with him that the inspector is not going to look at your twenty-seven, colour, glossy, photographs, with circles and arrows and a paragraph on the back of each one explaining what each one is. It's a case of American Blind Code Enforcement.Sure you can.
You may be able to persuade the dog though.You should know by the seeing eye dog he has with him that the inspector is not going to look at your twenty-seven, colour, glossy, photographs, with circles and arrows and a paragraph on the back of each one explaining what each one is. It's a case of American Blind Code Enforcement.
I don't know. It might be kind of... ruff.You may be able to persuade the dog though.![]()
On second glance I can see how my post could be interpreted to mean- Suuuurrre you can.:roll: That is not the way I meant it.Is it legal or not?
