john2016
 - California
 - Electrical Engineer
If I have an existing 3P90A breaker in a panelboard located in the electrical room and need to change out the existing breaker in the mechanical room to a 3P60A enclosed breaker on the other end feeding an air handler that is being replaced in the mechanical room located across the building is this allowable per code?  The wire size from the 3P90A breaker is 3#2, 1 #10GRD going to the 3P60A enclosed breaker.  From the 3P60A enclosed breaker to the AHU the wire size is 3#6, 1 #10GRD. Thanks.
