Different answers regarding best option for wire or cable to accessory building…
Kh82nj
New User
Orlando, FL
Real Estate
Located in Orlando, FL. Running power to an accessory structure from primary home. 125Amp in non-metallic pvc conduit buried 24” 300’ to structure. The building is 1000sf and has laundry room with washer/dryer, kitchen possibly in the future (the reason I want 125A service is to never need to upgrade), on demand propane water heater, 1 bed, 1 bath, 2.5ton AC unit with condenser and handler.
Running several wire calculators to keep around the recommended although I understand not required 3% in drop is giving me a pretty big and costly cable.
Trying to save money and handle the underground and service myself then learn as I go.
Just today I was recommended to go with (2) 2 aught, (1) 1 aught for neutral, and #2 for the ground.
Any help would be appreciated as I just want to do it the right way one time and the different specs of wire are a bit confusing to a novice.
Thank you in advance!
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
