different sizes of Pole Mounted Transformer.
powerplay
I noticed on a Sawmill that one group of three phase Transformers had one "Transformer Can" that was smaller than the others. I didn't notice any markings it, and was wondering if it is simply an different design?
powerplay
Electrical Room access
I was wondering if an 480 volt Three Phase Splitter is permitted to be on a wooden mezzanine off the Floor, or if the platform access would be required to be non-combustible?
mivey
The sizes can be suprisingly different for the same kVA.
kwired
Electron manager
NE Nebraska
That or it may be a high leg delta system with large lighting pot and smaller high leg pot because the amount of load on the high leg is minimal in comparison to the other legs.
mivey
It is not an open delta so both high leg pots would be small, not just one.
big john
Portland, ME
if the 3 phase is small compared to the single phase load, The transformer providing the single phase load will be much larger.
Right, but he's saying he had two large, one small. That would mean two heavy phases, one light phase. That don't make no sense.
domnic
Electrical Contractor
Three pase splitter
Three pase splitter
What is a three phase splitter ?
peter d
New England
Occasionally I will see this where one of the transformers in the bank has failed and they replace it with a transformer made by a different manufacturer. However, if they transformers are old enough, they will replace the entire bank.
fmtjfw
I assume there are no two or three digit numbers painted on them. If so, it's likely the KVA rating.
If you have a good spotting scope and a tripod, -- or a bucket truck -- you might be able to read the nameplates.
