Different type power
siva
Hi
Why US and some other countries use 120 V,60 hz and 240V,60 hz etc and some other countries like UK use 230 V,50 hz and 440 V,50hz.Why we have these types of varieties in power generation and distribution? What are the advantages and disadavntages over each systems?What are the major factors involved in selecting these systems?
Thanks in advance
Siva
Re: Different type power
The US alternating current system was designed by Nikola Tesla and Westinghouse for the Niagra Power Station. 60 hertz was deemed the best frequency for both efficiency of power generation and distribution. Above 60 hertz, the electrons in conductors tend to migrate to the "skin" of the conductor making the conductor less effect in ratio to its size and if you keep raiseing the frequency, the electrons will actualy "jump" off the conductor as radio waves. Below 50 or so hertz, lights will actuall begin to flicker from the series of on's and off's during an AC cycle. However, some transit systems still use 25 hertz systems to run the vehicles.
Meanwhile, a German company called AEG controlled the power distribution and generation throughout Europe. They choose a 50 hetz system. So wherever European countries had colonies and influences, the 50 hertz system spread there. Everywhere the US had ties, the 60 hertz system was put into place.
Tesla was not a fan of the 110v system, but Edison had selected this voltage earlier for his 3-wire DC system. westinghouse was afraid people would be afraid to use electrical power from the AC system if it was not similar to that of Edison's established system. Besides, everything was already rated and designed at 110V in the US.
In Europe, voltage drop and power loss is more of a problem both becasue of the 50 hertz system and the lack of generating facilities as compared to the US. They needed to raise the voltage of their systems to allow them operate better.
In my opinion, this country adopted 60 Hz system, because of the 12 based mesurment system. Generators synchronos RPMs are 3600 (2 pole), 1800 (4 pole), 1200(6 pole) RPM etc.
In contrast the Europe has 10 base system 3000 (2 pole), 1500 (4 pole), 750 (6 pole) RPM etc.
It should be noted that the voltage drop has nothing to these low frequencies. Europe had at least 10 diferent voltags in the begining of the century. In the end the German AEG won the 'standard' 380/220 Volts with the coresponding US 208/120 Volts. Same thing happened with the VHS format in the video recording industry.
I think the Westinghouse adopted 120 V in order to comply or compete with the Edison's curent 'standard'. You see for the incandescent lights 120 AC or DC does not make any differnece.
Niagara Mohawk power company used to have 25 Hz power in the Niagara Falls area. I think most of the loads have been replaced.
stuart in mn said:
The one I never figured out was Japan - half the country is 50hz and the other half is 60hz.
That's not any worse than Indianna. Part of the state has daylight savings time, and part doesn't.
What time is it? 3:00 oclock or 4:00 oclock at Bob's house.
Steve
I know in the Navy we had special frequency generators on an aircraft carrier. Some producing 400 Hz and others 1000 Hz. I am just curious after reading at what frequency do the electromagnetic "waves" become radio waves?
"Radio wave" is really meaningless. Even 60Hz and below is in the ULF (ultra low frequency) band of the electromagnetic spectrum. It is quite capable of propagating over considerable distances given a suitable radiator.
I believe frequencies in the ULF band were (or are) used to communicate with submarines under water because of the low attenuation of the water on those long wavelengths.
-Hal
