Hoping you guys can enlighten me. It's come to my attention that the normal method for installing overhead services in my area (southern California) might not be acceptable in a lot of AHJ. I attached a picture of an older combo meter main panel. It has a 100 amp service disconnect and bussing for breakers. The panel is flush mounted and the mast for the overhead service is inside the wall. Although it is an older installation, this method is still widely used in my region. My two questions are:
(1) Are combo panels with meters sockets, service disconnects, and breaker bussing uncommon in other regions?
(2) Are overhead services, including the mast and meter panel, typically always surface mounted in other regions?
