I am installing 4 digital timer switches for a friend. He bought the switches and I said sure I will wire them up. The switches require a neutral and there is conduit run in the building, so I yank the neutrals down from the junction boxes overhead. When i get everything made up and turned on the switches turn off and on sporadically. The only thing I can come up with is, The load is florescent and what paperwork comes with them does not say directly that they are good for florescent loads. The load being drawn on the 1 switch I was troubleshooting is only .52 amps. Do i need to find a different switch or go with a time clock?
Any insight would be appreciated
Thank You
Thank You
