mstrlucky74
- NJ
If you have a lot of strut mounted to concrete for your conduits how do you guys install anchors? Drill holes then use a wedge anchor or powder actuated guns?
Thanks
Thanks
This is the setup I use also. Sometimes I'll use tapcon's depending on what it is.For racks and threaded rod we use these or for mounting hard to a surface the same anchor with a hex nut instead of the rod coupling:
For the holes we use these or something similar:
we use to use wedge anchors but then our Engineering guys decided to just pre-empt any trouble with break out along edges-- so all we use now are epoxy anchors
