Diming a transformer can
peter d
New England
Re: Diming a transformer can
Sure. Just make sure the dimmer is suitable for use with a transformer. Is the xformer magnetic or electronic? Either way, you would need a specific dimmer suitable for the type of transformer.
Magnetic low voltage dimmers are expensive, but
if it's electronic, then you will be paying considerably more for the dimmer. :eek:
jimwalker
TAMPA FLORIDA
Thanks we were getting yeses and no.We will be putting dimer on the 120 volt side,this is a magnetic transformer.Will this fit in a standard 4 square ?
peter d
New England
It depends on hom much stuff is in the box allready. ;) The case for a low-voltage dimmer is no different than any other dimmer. It takes up a lot of room and can be a pain to install in crowded boxes. :roll:
davedottcom
Check the Transformer, some are marked "Not For Use With Dimmer"...although I don't know why!?!?
I'm talking about the one I have...a 150W "Plug in" type used for 12 V. lighting.
Maybe the manufacturer acknowneged the fact that dimmimg an outlet is a violation. ???
Dave
