Read up about these on Lutron's website. There is quite a bit of how to info. They are not the only manufacturuer, but they are usually considered the premium.
You have to decide how low you want to go (10%, 5%, or 1%) Note that 1% actually looks pretty bright, so it's not like incandescent where you can totally fade to off (Almost though).
The most important thing (and a maintenance PITA) is that you need to run them at 100% for 100 hours before you try to dim them! This is called seasoning. It's pretty easy to accomadate in new construction, but what happens over the life of the building? Group relamping can help with this, along with a timing relay that shunts them to on for 100 hrs of runtime when a button is pushed.
Mike
