Srv52761 Senior Member Location lowa Occupation Energy Manager Sep 26, 2020 #1 I have six 12 watt, low profile, dimmable LED luminaires. I want to be able to dim them AND run them on a timer. Do they make a combo timer/dimmer switch? I could not find any.
mopowr steve Senior Member Location NW Ohio Occupation Electrical contractor Sep 27, 2020 #2 I don’t think I ever found one either
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Sep 27, 2020 #3 You'll need two devices. Wire the timer first, the dimmer second.
M marmathsen Senior Member Location Seattle, Washington ...ish Occupation Electrical Contractor Sep 27, 2020 #4 The closest thing I know of would be something like these motion/dimmers. It obviously has a built in timer after it stops sensing motion. https://www.lutron.com/en-US/Products/Pages/Sensors/Occupancy-Vacancy/MaestroOccVacSensors/models.aspx#Passive%20infrared%20Occupancy/Vacancy%20Sensor%20C%C2%B7L%20Dimmer Rob
synchro Senior Member Location Chicago, IL Occupation EE Sep 27, 2020 #5 Leviton makes a dimmer with a timer that's programmable from a smartphone over a bluetooth connection: https://www.ideadigitalcontent.com/files/10962/ID-SPE-v1-DDMX1-BLZ.pdf https://www.leviton.com/en/docs/G-9626A_Decora_Digital_Quick_Guide_final.pdf
