C chaddavis New member Jan 20, 2009 #1 is there any code for putting a dimmer on a half switched outlet suffolk county new york
roger Moderator Staff member Location Fl Occupation Retired Electrician Jan 20, 2009 #2 If they follow the NEC 404.14(E) would prevent it. Roger
Dennis Alwon Moderator Staff member Location Chapel Hill, NC Occupation Retired Electrical Contractor Jan 20, 2009 #3 chaddavis said: is there any code for putting a dimmer on a half switched outlet suffolk county new york Click to expand... Lutron makes a recep. designed for this situation. If you notice that the top half has a a burl sticking out so that a special plug must be used for it. You can find the male part in this pdf.
