131026-2318 EDT
mivey:
My goal was not to find an optimum high accuracy means to make the measurement. For that I would probably use a zero-crossing detector and a counter timer. Rather I wanted a quick and dirty means to verify that I had not made a calculation error in the calculated determination of an RMS value. With my scope presently dead it could not be used. Input source voltage can be controlled to 0.1 V at 120 V. Then the average DC voltage for the experiment can be calculated. Phase shift adjusted to get this value, 27 V, can be done to 0.1 V. Now read the RMS voltage of the waveform. Accuracy good enough to verify no major error in the RMS calculation.
Some error points are:
Non-simultaneous readings and some line voltage fluctuations.
Voltage drop across the dimmer Triac.
Voltage drop across the DC measuring diode.
Waveform distortion.
Different phase angles will result in different accuracies.
The intent of the post was simply to initiate a discussion, which it has.
