fireryan said:Does a fan control vary frequency and a dimmer vary voltage? And can you use a fan control on a small motor.
So you are saying I can use a fan control for a small motor but not a dimmer?K8MHZ said:It will work for a while and then burn the motor out.
A fan on our fireplace was controlled with a dimmer switch. Although it did last several years, it still cooked the motor eventually.
Since electronics have become smaller over the years, I can see how it is now possible to put a VFD into an area the size of a switch.
fireryan said:So you are saying I can use a fan control for a small motor but not a dimmer?
