quogueelectric
- new york
I occasionally have customers asking me why thier dimmers make noise and what they can do about it. I dont really have a good answer for them does anyone else have an explanation and or solution??
allenwayne said:It hums because it doesn't know the words!
Finally found something the megger can't do, ey?mdshunk said:I hate to say it, but the solution is often a trial and error situation.
No, a megger might actually solve the issue. Leave the dimmer connected, and megger it. The megger will blow it up, and you'll have to replace the dimmer. That might solve the issue.georgestolz said:Finally found something the megger can't do, ey?![]()
mdshunk said:No, a megger might actually solve the issue. Leave the dimmer connected, and megger it. The megger will blow it up, and you'll have to replace the dimmer. That might solve the issue.![]()
? Select another brand of lamp or use lower wattage lamps (100W or less)
? Use rough service lamps
? Use a physically smaller lamp
? Install a lamp debuzzing coil in the lighting circuit, see pg.189 *1
