G
Guest
Guest
Per 2002 NEC is it permitted to have a dimmer connected to a duplex receptacle??
This is my first post here, and I'm bringing up an old thread on 404.14(E)... I guess what I don't understand is, can't you plug some other load into that kitchen exhaust fan receptacle? Realistically, couldn't you plug anything into any receptacle? i.e. what's stopping me from plugging in a car to a receptacle instead of an appliance (this may not be the best analogy, since a car would be running on DC, but you still have two terminals that you could wire into a standard plug). My understanding was that prior to these changes you could just label the outlet "lighting only" and you'd be ok. If someone has a lamp that can't be wired directly into the wall that they really want to dim, is there not some way to make it clear within the code that only this type of load can be plugged in? What about some way that would lock the load into the receptacle so that it could not be removed any more easily than rewiring the entire receptacle.Originally posted by charlie b:
One example of the "other loads" is a kitchen exhaust fan. I have one installed in my kitchen, and the dimmer is listed for that specific load. A general purpose receptacle would not qualify, because the listing of the dimmer could not explicitly include every type of load that could be plugged into the receptacle.
