cvirgil467
- NewYork
Anyone know if 125V, 20A duplex receptacles connected to a dimming panel is an NEC no-no?
Uh, if this was in the same room, I'd say the receptacle could be feeding the switch, which is supposed to be dimming the lights on the ceiling fan. Perhaps?Originally posted by sceepe:
Went over and found the receptacle near the bed had been wired to a wall box dimmer.
Also found 4 ceiling fans wired to the unswitched hot.
That might be what they had in mind but didn't get hooked up that way. Slide the dimmer and watch the lamp plugged into the outlet dimm. Didn't try it with the TV but I wonder what would happen.I'd say the receptacle could be feeding the switch, which is supposed to be dimming the lights on the ceiling fan. Perhaps
