Oakey
- New Jersey
I have an older home with knob and tube wiring. Mostly the neutrals are switched for the lighting, is it feasible to install a dimmer on these switches?
Oakey said:I have an older home with knob and tube wiring. Mostly the neutrals are switched for the lighting, is it feasible to install a dimmer on these switches?
SiddMartin said:if a dimmer is limiting the voltage to the light, how could you dim on the neutral which is coming back from the light? maybe someone could explain this to me![]()
