I am currently working on an old strand dimming system CD-80 and have discovered that when originally wired that a number of neutrals were pulled to the dimmer rack that were too many for the correct amount of circuits. another way to explain it is that there are multiple lights with a separate neutral, but only one circuit dimmer supplying with one hot phase. Is this an issue or is it fine to leave it this way. I know that the dimmed load uses the neutral as the return path, Is the fact that the neutral conductor has lots more length of wire to return on is a problem or not.????
