Mike The Mute
- Canton, GA
I've never been a fan of Tech Lighting. It's like painting a turd gold, all you end up with is a gold colored turd. Anyway, my latest problem has been that my customer wants to use Lutron Maestro series dimmers. I installed an Electronic Low Voltage dimmer at the switched side of the 3way (as per directions to tie the swith leg neutral to the dimmer), but it hums so loud I can almost tell what it's saying (at the transformer). It was a 1000w dimmer.
The manufacturer was useless. Typical. Today it seems like all technical questions are answered from a computer prompting them as to what to say. Whatever happened to trained technical advice? Guess we have Mike Holt to thank for there still being somewhere to turn.
I'm not one for trial and error. Especially when it may burn up an overpriced, lead-laced, "made in china" gold turd of a transformer. Anyone out there know what may be the best solution?
Thank you all, Mike
P.S. During the install there was a series of issues of shorting out the coax style wiring that feeds/supports the 5 pendants coming from the transformer. Is it possible there is enough of a short to make the dimmed fixture hum, but not enough to cause a noticeable problem without the dimmer?
P.P.S Just an example of what you get for a grand: The 3 metal rods that support the outer glass away from the inner is done in a way that when the rod heats up from the halogens, the rods broke one of the outer glasses. $80 and no admission of guilt from their engineers.
Thank you all, Mike
