What is DIN XXXXX (for example DIN 43653)? Is 'DIN' a standard type of fuse?
DIN stands for Deutsches Institut f?r Normung (German Institute for Standardization) . DIN 43653 is a standard for "High rupturing-capacity fuses for semi-conductor converters". You'll also see "BS###" which is British Standard, like BS 1363, which specifies the most common type of single-phase AC power plugs and sockets that are used in the United Kingdom.
Thanks for the info. Is there an online document to look these up? I can't find any online reference to DIN.
