I dare you to install a 50 lb fixture on one of those fiber boxes.Originally posted by physis:
An outlet box istalled as required by 314.23 can hold up to 50 pounds.
[/QB]
Isn't that overkill for my porcelin keyless fixture. I hate ceiling fans in these locations.dining rm. & 2 story foyers
What does not make sense is that everyone is missing the real intent of the code.It seems to me that the cost of installing a weight bearing box just makes good common sense.
Especially in ceilings above 10 feet.
There is no requirement to use the box as the sole support, and to even go farther if the fan is heaver than 35 pounds you are not allowed to use the box at all for support unless it is listed:D) Boxes at Ceiling-Suspended (Paddle) Fan Outlets. Where a box is used as the sole support of a ceiling-suspended (paddle) fan, the box shall be listed for the application and for the weight of the fan to be supported. The installation shall comply with 422.18.
So what do you do with a Casablanca fan that wheigh's 150 pounds? Even a listed box is not allowed to support a fan per 422.18(B)(B) Ceiling-Suspended (Paddle) Fans Exceeding 16 kg (35 lb). Ceiling-suspended (paddle) fans exceeding 16 kg (35 lb) in weight, with or without accessories, shall be supported independently of the outlet box . See 314.23.
Exception: Listed outlet boxes or outlet box systems that are identified for the purpose shall be permitted to support ceiling-suspended fans, with or without accessories, that weigh 32 kg (70 lb) or less.
