So I'm doing a service upgrade for my Brother on a home he just bought in Southern California and along with a multitude of code violations I also found that there is what looks to be a large diode attached to the incoming "neutral " prior to the conductor lug on the power companies side
it's old and just solid black with no visible text or embossing has anyone come across this before? And the only thing I can think of is that there was some type of current present because the ground was undersized and poorly bonded to the cold water line about 20 feet into the attic. Just want to know If i should be worried about not putting it back so long as I install a 5/8 ground rod
