Direct Burial Cat 5E???
Alwayslearningelec
NJ
Estimator
I am working on a job with a vast amount of site lighting. It show about 2000' feet of direct burial cat 5E. Can you put this cable directly in the ground without a raceway?
Thanks
You can buy CAT 5e that is specifically made for direct bury ($$$). Manufacturer's don't recommend burying regular cat 5e with no conduit protection though.
there are several types of direct burial cat5e. youve got flooded (filled with sticky goo that seals any cuts in the jacket to keep water out), non flooded, and a couple different types with an overall metal armor, flooded and unflooded. I would install conduit then use a non flooded cat5 inside that. (flooded would be better but is a pain to work with)
