You may be able to use this:
422.34 Unit Switch(es) as Disconnecting Means. A unit
switch(es) with a marked-off position that is a part of an
appliance and disconnects all ungrounded conductors shall
be permitted as the disconnecting means required by this
article where other means for disconnection are provided in
occupancies specified in 422.34(A) through (D).
(D) Other Occupancies. In other occupancies, the branchcircuit
switch or circuit breaker, where readily accessible
for servicing of the appliance, shall be permitted as the
other disconnecting means.
