Hello:
I need some help from some of your pro's. I have a problem at one of my rental properties, in that I have an open neutral that I am trying to trace. In trying to trace it, I came upon a problem I have no idea on how to solve.
In any case, the tenant reports that the two switches that run the two lights in the kitchen do not work (all of a sudden, after working fine for the last five years). I tried to find this for two days, and I brought in an electrician today, since I could not find the problem.
Currently, the hot that feeds the two kitchen switches (both are single pole), and the neutral at that point read 118.5 volts. However, once a load is connected to this hot and neutral, the voltage drops to almost zero. I have taken the switches out of the equation, and connected a pigtail light across the hot and neutral, and the light does not go on.
In other words, the circuit appears fine as long as there is no load across it, However, once a load is connected, the voltage disappears. Both I and my electrician (who is a union electrician and also an electrical engineer) are baffled as to what could be causing this.
Does anyone have any ideas?
