gotmud
- some place cold
Hey went to wire a roof top a/c...inside the disconnect there was no ground bar/lug there...It used to be grounded by the previous person running sealtight from inside the building to the a/c disc....NOW the inspector says NO WAY can I use sealtight to ground an a/c on a roof as long as the disconnect is mounted to the a/c unit...SOOOO i'm running a ground through the sealtight to the disc...What do I hook it to.....
