Installing electric heat FCU's. 424.3B says wire and breaker must be 125%. Have to install pullout disconnect (not fused) because breaker is out of sight. Actual load is 55 amps. Is 60 amp ($11) pullout ok (are all considered continuous?) or must I go to higher rating (125% also) which ends up as a 100 amp disconnect switch at over $100?
Thanks for the help.
Also, please check 480/277 multi-wire question.
